Automation in the Age of COVID-19
Ed Sinkora
By Ed Sinkora Contributing Editor, SME Media
Safer, faster, and more intelligent solutions aid industry in a pandemic
Collaborative robots are easier to implement in part because they can be trained by manually dragging the robot head where you want it to go.
The longstanding trend toward manufacturing automation has understandably been accelerated by the COVID-19 pandemic. Roughly a year into the crisis, it’s a good time to ask about longer term impacts. Has the pandemic pushed automation into new areas? Have suppliers made automation more flexible? Easier to implement?
By their nature, collaborative robots (cobots) are easier to implement than their traditional cousins. Because cobots are designed to share a workspace with their human counterparts, as a matter of routine, they often don’t require guarding and can fit into relatively small, occupied spaces (when confirmed by safety risk assessment). They’re also easier to set up, said Dick Motley, the Director of FANUC America Corp.’s authorized system integrators group in Rochester Hills, Mich. He explained that a user can, in part, train FANUC’s CRX series cobots by literally grabbing the arm and leading it around. This makes “setup of a simple application really straightforward and intuitive. You’ve got robotic automation that can be deployed quickly.” He added that “there’s a growing ecosystem of peripheral suppliers for grippers and pedestals for the robot to sit on, and different provisions to easily address the utilities that go out to the robot’s end-of-arm tool.”
The bad news is that cobots are slow. Even though they’re built with sensors that limit the force they’ll impart if they come into contact with something, “it’s pretty tough to meet safety standards at high speed,” explained Motley. “Because regardless of how sensitive your contact sensing system is, you’re trying to defy physics if you’ve got something moving really fast and then need to immediately bring it to rest.” So although you might think cobots would be taking over the world of automation (and COVID-19 era sales have been explosive), their applicability has limits.
Promess is automating its Electric Workstation with a cobot and eliminating the need for a separate inspection station by incorporating a camera (right). The upper indexer is a tool changer, offering staking, pressing, probing, or rotating tools (shown in multicolors), depending on what process is needed.
Motley referred to “a relatively low-speed palletizing operation” at the end of a customer’s manufacturing lines as a good fit for a cobot. “They were making two to four cases of product a minute, with an incredible density of conveyor lines feeding these products down to the end to be palletized. They didn’t have the physical space to do a traditional robot implementation with the stopping distance calculations and all the things that go into a traditional robot cell. Their only automation option was to put in a cobot. … If you go slow enough, a cardboard box is probably not going to hurt you.”
Safe and Easy for Humans
This is not to say that traditional robots can’t operate in proximity to people, or that they’re very difficult to set up. Or that slow-moving cobots can operate without guarding if they’re handling something sharp or otherwise dangerous. To address these concerns, FANUC and other OEMs have systems that “restrict either the motion range or the speed of the robot” to allow for intermittent interaction with a human, explained Motley. FANUC calls its safety architecture “Dual Check Safety,” or DCS. “Maybe you want to establish a ‘keep out’ zone on one side of the robot while an operator loads parts or something that the robot is going to retrieve. You enable a software constraint to keep the robot from going there, typically reinforced by a light curtain or a safety mat or a scanner. But then, once the person leaves that loading zone, the robot can be right back up to full speed.”
Motley also pointed out that “adjustments to DCS can be done in FANUC’s Roboguide offline programming environment simulation package. They can be done with a laptop attached to the robot, or with one of our user interface devices, whether it’s our iPendant or our new Teach Pendant tablet.” The new tablet-based interface is particularly easy to use, said Motley. “It’s a whole new programming style that’s not even close to computer language. It’s a drag-and-drop icon timeline.”
At Promess Inc., Brighton, Mich., Director of Application John Lytle reported that the pandemic has accelerated his company’s effort to make its Electric Press Workstations perform additional functions. Promess had already made it easy to add its units to a production line by making them compact and self contained, with an integrated light curtain to prevent injury to the operator. “They automate assembly with sensing that determines if it made a good part, and you can put them wherever you want and adapt to things as they change in the plant.” Promess has added ancillary functions and enhanced the information the units are able to communicate to the rest of the factory. For example, in addition to pressing two parts together and confirming that the measured force and travel were as expected and the assembly is therefore good, the Work Station might also take dimensional measurements and pass that information along. This eliminates the need for a separate gaging station.
Automating logistics—with its diversity of items and need for speed—is driving the development of AI and advanced image processing.
Performing such measurements requires cameras and/or lasers, and Promess integrates the technology such that the end-user still gets a stand-alone, “plug and play” unit. As Lytle explained, “We’re focused on making it simple for the end user, so it’s not like a big science project requiring a camera technician, a PLC expert, a high-level integrator, and so on. We have a software team of 20 people here, working every day to make it easy. So when the customer gets a Work Station, it’s already set up. They’re just entering parameters.” He added that cameras can do more than measure parts. They can also be used for part orientation. This enables more complex arrangements, like being able to automatically pick from multiple parts on a pallet. Plus Promess has integrated cobots for automatic part load/unload. The end result, as Lytle sees it, is a multi-function Work Station that simplifies the transfer line and contributes to social distancing, while also sending data to the other equipment in the plant “via the Internet or Intranet to make a decision about what to do.”
More Intelligent and Flexible
According to Joe Chudy, general manager of ABB Robotics USA, Auburn Hills, Mich., “all industries, in large and small installations, are looking for ways to remove people from their processes.” The biggest increase in demand—a boost that can be tied directly to the pandemic—is in medical manufacturing, packaging/logistics, and food processing. The latter two are particularly challenging, given their need for extreme speed in the face of inconsistent inputs. As Chudy put it, “it’s no secret that Amazon can’t hire enough people and can’t automate quickly enough. The same is true of WalMart and everyone else in that space. But the quantity and diversity of the items you have to pick up and sort quickly forces you to implement some form of AI (artificial intelligence).”
With smart scheduling software and versatile pallet handling, Fastems’ higher end automation systems enable the manufacture of different products over extended periods without human intervention.
Chudy said the food processing industry is also hard pressed and driving automation innovation. He described meat cutting and packing as an inherently miserable environment for humans to work in, with the pandemic only adding to the woes. And the “protein” (as the industry refers to their product) varies from piece to piece. “We asked ourselves if we could debone a chicken. What could we do with the wings? Things like that,” recounted Chudy.
Given the inconsistencies of the forms of the protein, meeting this challenge required both a smart camera system and AI to orient the robot grippers. “There’s also quick payback on limiting the protein lost in making the cut,” added Chudy. “So the vision technology you use, with water knives or other techniques to cut this material as close as you can, is a big deal. Learning how the protein is presented to the robot, where the vision system should go, and how you should orient it, all factors into the application.”
Long term, Chudy thinks, advances in AI driven by these challenges will also be applied to the metalcutting world. For example, random bin picking capability is improving due to improvements in AI, he observed, “as well as de-palletizing and some of the logistic [tasks]. Acquisition times are really what matters in random bin picking. How quickly can I locate that part? How fast can I go get it? It’s the same in the logistics market.” Chudy believes speed is important and processing the volume of image data required to pick the parts has until now limited those applications. “[Now] we’re seeing those applications flourishing in this market as the technology grows and becomes stronger and less maintenance-intense,” Chudy said.
He said fixtureless welding and smart welding are also being studied, in which “you’re presenting the piece and part to a camera and it’s deciding how to weld it, and the tolerances, and measuring the gaps, and doing all the things a traditional programmer would do. It works well in the lab, but we have not implemented it in production yet.”
Fagor Cloud software enables machine monitoring on any Internet browsing device with the correct credentials, and Fagor’s use of HTML5 ensures the interface appears the same on any device.
Vision technology is central to these systems. And as Chudy put it, that used to “make a lot of guys in the metal industry nervous,” because vision systems previously required specialized technicians to install and maintain. “Now these newer applications are able to self monitor.”
Motley also spoke of vision technology as a tremendous enabler that has gotten easier to implement. “When you give a robot eyes to be able to adapt to the environment, that enables all kinds of things in terms of reduced cost for setting an application up, reduced changeover time, fewer changed parts, better flexibility, higher reliability, and in-process inspection.” He said FANUC’s new 3D vision technology, called 3DV, offers “a versatile, compact sensor that can easily be built into end-of-arm tooling on a robot. The robot literally carries its eyes around with it rather than having just a stationary sensor, although stationary sensors still have their place.” And a 3D point cloud provides the robot with much more information than a flat 2D image, he added. With more information about what’s in front of it, “the robot’s control is better able to decide what to do next.”
Manufacturing in Metal
Handling packaging and protein is a lot different than a typical metal working application. So, as Dave Suica, president of Fastems LLC, West Chester, Ohio, explained, gripper technology is changing. “We have started going to servo-controlled grippers. A lot of the parts are deformable. A regular power gripper can apply too much force, more than what’s needed to overcome the friction factor to lift the part. With servo-control, you go to a position, and then it has an override for how much pressure it applies.” More generally, Suica said people are tending toward “higher end” automation that doesn’t require manually changing grippers in order to switch jobs. “With smart automation and automatic gripper changes, and computer control versus a PLC, you can make it dynamic. You can switch from part A to part B to part C without any people there. We have systems that run for 72 hours autonomously.”
The ability to automatically change grippers makes robots even more flexible. Fastems is also using more servo-controlled grippers to handle deformable parts without damage.
While Fastems is best known for large flexible manufacturing systems (FMS), its handles the entire range of robot and pallet handling configurations. Suica said the pandemic has caused some companies to buy and automate single machines just to quickly re-shore a certain product. But whether Fastems delivers a large FMS or a robot for a single machine, “it still has a full line of manufacturing management software,” said Suica. “It still has scheduling. It still has the capacities to run different parts at different times.” Fastems prides itself on being able to integrate with a company’s ERP system for predictive and dynamic scheduling. “So, as the ERP system changes the requirements, we automatically change the sequence of what part gets made when, such that you maintain your flow without building inventory.”
Returning to the packaging and assembly challenge, Motley said FANUC’s automotive roots have served it well. “Our ability to dispense a bead of sealant to seal up a car body prior to painting, and coordinating that very tightly with robot motions such that when you go fast, you don’t get a thin spot in the sealant bead … and when you go slow around a corner you don’t get a big, thick pile up …” contributed directly to being able to dispense adhesive in assembly operations.
Remote Control Moves to HTML5
The increase in automation and social distancing driven by the pandemic has in turn highlighted the need for remote monitoring capabilities. Remote monitoring isn’t new, and virtually all control, automation, and machine manufacturers offer such solutions. But Fagor Automation–USA, Elk Grove Village, Illinois, recently went a step further by accelerating the release of an HTML5 based control architecture. As General Manager for North America Harsh Bibra explained, HTML5 is not only browser based, it’s “consistent across multiple browsers. One person might be using an iPhone. Another might have a Google device. A third person could be using Windows 10 on a laptop. With an HTML5-based interface on the machine, they would all see the same thing in a similar way. HTML5 makes your machine platform independent.”
HTML5 provides better mobile access to business intelligence too, said Bibra, along with geolocation. With geolocation, he pointed out, you can limit remote connections to devices that are in specific locations, thereby improving security. For example, you could limit a remote connection to an employee’s house, but not elsewhere, to prevent access if the employee lost his phone. What’s more, added Bibra, “HTML5 is without limits. Depending on the power of the logic you write, or the power of the human- machine interface you create, it can provide the Nth degree of freedom in the sense that the person on the other end can have access to anything.” That means you could empower a remote connection to not just monitor activity, but also enter machine commands, like cycle start or cycle stop. In other words, remote control is the ultimate in social distancing.
    LIFT Activates 3 Programs as Part of Advanced Materials Challenge
    PRESS RELEASE: LIFT December 4, 2025
    LIFT, the national advanced materials manufacturing innovation institute, operated by the American Lightweight Materials Manufacturing Innovation Institute (ALMMII), today announced it has launched three initiatives as part of the Advanced Materials Challenge.
    Tariffs and Trade Wars Are Reshaping the Supply Chain, Report Shows
    Rachael Thomas December 4, 2025
    The impact of escalating trade pressures, climate events, labor issues and cyber threats is at the forefront of EcoVadis’ latest sustainability report.
  • MANUFACTURING ENGINEERING
    Heating Up for Energy Efficiency
    Cary Gitter December 4, 2025
    How do you transform a 50-year-old manufacturing facility into a model of modern sustainability? This was the challenge facing Schneider Electric USA Inc. at its 213,500-sq-ft (19,835-sq-m) Lincoln, Neb., plant, which operates 24/7 to produce molded circuit breakers mainly for the residential market, using injection-molding processes. The factory is the company’s second-largest energy consumer in North America and, according to 2023 data, contributed about 840 tons of Scope 1 (direct) CO₂ emissions.
