Marposs Introduces Optoflash XS30
By Marposs Press Release
Marposs, a world leader in measurement, inspection and test technologies, on March 30 announced via a press release the OptoFlash XS30 – the latest addition to 2D optical measuring solutions in the company’s offerings. It is designed to meet the requirements of the precision mechanical devices industry as well as the medical implants industry, both molded plastic and machined metal. OptoFlash XS measures small chamfers or grooves, including below 100 µm extension, or very small changes of diameter along the part axis, thru hole diameters, Run-Out, perpendicularity, barrel shape, profiles and many more features. The company boasts its capability to switch from one-part type to another with just one click.
Marposs' OPTOFLASH XS30 is designed for precision measurement of very small components of plastic or metal.
Optoflash enables 100 static measurements within two seconds at U95 = 1 µm + D/200 (D in mm). The OptoFlash XS30 provides ultra-high-resolution measurements for ultra-small size parts up to 30 mm in part length and 20 mm in diameter.
Measuring at 610 mm x 545 mm x 400 mm (2’ x 1.75’ x 1.25’), the OptoFlash XS30 is a compact size solution designed to be integrated in the production environment as well as in the lab. It accommodates both manual and automatic loading by robot, as well as dynamic or static measurement.
All OptoFlash systems feature an intuitive interface and measurements are archived for retrieval by the smart search function. The included monitor comes on a flexible arm that can be installed on either side of the system. An integrated USB hub with seven ports provides connection to printers, code readers or external memory. The Ethernet port allows you to connect the XS system with your network anytime.
For more information on the OptoFlash XS30 from Marposs, visit http://bit.ly/marpossoptoflash.
  • VIEW ALL ARTICLES
