Optimization Module Tackles Tough Materials
Gene Granata
By Gene Granata VERICUT Product Manager, CGTech Inc.
Most anyone who’s worked in a machine shop for any length of time has at some point attended a trade show or machine tool distributor’s open house. There they see canned demonstrations of CNC machines busily carving up chunks of brass, mild steel, or aluminum into business card holders and tic-tac-toe games. While these giveaways are fun stuff, wouldn’t it be refreshing to see some real parts being machined, preferably from a difficult-to-machine material?
That’s what took place at the Okuma Winter Showcase, an annual event the machine builder hosts for 600+ attendees. At the event, attendees were treated to more than two dozen CNC machine tools under power, most of them making chips. These included an MU-8000V LASER EX super multitasker with laser metal deposition and the GENOS M460V-5AX, a trunnion-style, five-axis vertical machining center offering high productivity, a small footprint and a surprisingly low-price tag.
There was also an LB3000 EX-II lathe with barfeed vibration detection, a MULTUS B300II turn-mill center with collaborative robot part handling, MA-500HII horizontal and MCR-A5CII double-column machining centers and a MULTUS U3000 multitasking machine.
An impressive lineup, to be sure, but there was one demo that had a large number of show attendees talking, even those responsible for setting it up. “It was pretty cool to see, especially when you consider that we were cutting titanium, a very hard and difficult-to-machine material,” said Okuma Applications Engineer Lee Johnston.
He’s talking about the demonstration involving CGTech’s Force, a physics-based NC program optimization module that works within the company’s flagship VERICUT toolpath simulation software. Working with representatives from CGTech and Sandvik Coromant, Johnston programmed a Ti-6Al-4V titanium bracket being made for an aerospace customer, then optimized its toolpaths with VERICUT Force.
“We had the same demo on two vises and ran them side-by-side, one with the standard program and one that was optimized,” said Johnston. “We reduced cycle time from an hour to just under 40 minutes, and you could also hear and see the difference in how the tools were cutting and tell that the optimized program was easier on the machine. This is probably the best thing to happen to programming since trochoidal toolpaths.”
VERICUT Product Specialist Pete Haas explained that Force works by analyzing the NC toolpath, evaluating the changing cutting conditions and increasing or decreasing the feed rate to achieve the ideal chip thickness for any given material. Compared to CAM systems and online machining calculators, which attempt to determine average chip thickness and base the feed rate on that, Force calculates the optimal feed rate for every single line of machining code.
In VERICUT Force, blue line “spikes” reveal excessive or unsafe cuts in the original program, while red lines show gains and corrections made by optimizing. (All images provided by CGTech.)
“As an example, think about driving to work each morning,” Haas said. “You encounter straight sections, curves, and sharp turns, and have to slow down or speed up depending on the road conditions. Machining also involves constantly changing conditions, but some CAM systems don’t account for this. They generate a single feed rate that may be too aggressive on tight turns and too slow on the straightaways. Force, on the other hand, uses physics to calculate cut-by-cut throughout the changing conditions and determine the optimal feed rates.”
The result, according to Haas, is greatly reduced cycle time, improved tool life, better part quality and less wear and tear on CNC machine tools. It works on any material and any machine, and can even be used on legacy programs.
Johnston wasn’t the only one surprised by Force’s capabilities. Even CGTech Technical Support Engineer Chris Davala—someone with 20 years of experience as a machinist and programmer who now works with VERICUT customers across the country—said the demo was an eye opener. “To be honest, I was a little skeptical,” he said. “This was my first hands-on experience with the product, and it’s not that I didn’t have faith in the people who developed it, but there were some bold claims made about the potential gains. I can truly say that, after seeing Force in action, it’s made a believer out of me.”
That’s an easy thing to say for someone employed by the product’s developer. But Sandvik Coromant MTS Specialist Richard Howard, who worked alongside Davala and Johnston setting up the demo, backs it up. He supplied the cutting tools and toolholders used for the demo and specified the initial machining parameters.
“As a tooling specialist, I am extremely impressed with how ‘spot on’ the Force software is,” he said. “CGTech has done an amazing job of optimizing programs while taking into consideration tooling geometries and resulting loads. Anyone interested in higher efficiency and prolonging tool life should look into this.”
Anyone familiar with Okuma machine technology might consider Force unnecessary. That’s because the OSP control offers advanced features such as Machining Navi, SERVONAVI, Super-NURBS and adaptive machining technology. How can a third-party software package make a top-notch machine tool perform even better? There are several answers:
  • Force has the ability to break up the NC code into smaller bites, adjusting feed rates to maximize chip thickness and keep it constant.
  • Its optimization capabilities are proactive, not reactive, so everyone knows what to expect before pushing the cycle start button.
  • Performance issues are clearly identified up front and the programmer can examine the Force charts that illustrate projected cutting forces, chip thickness, feed rates, tool deflection and more.
For new materials, new machine tools and cutters, or even new programmers, Force eliminates the guesswork that would otherwise occur.
The result is an NC program that’s both safer and more predictable, with low risk of tool breakage or scrapped parts. Operators have more confidence. Lights-out machining is performed with confidence. Profit margins are improved. And Force-optimized toolpaths “save a great deal of time during roughing,” said Sandvik Coromant’s Howard. Parts are machined faster and cutting tools last longer.
In the Okuma demonstration, the VERICUT Force Optimized finished part on the left was produced more than 20 percent faster than the original programmed part on the right.
Haas summed it up like this: “Force charts provide NC programmers with useful information they never had before. They can quickly and easily visualize what’s happening cut-by-cut as the tool moves through the material and it’s now possible to visualize excessive forces, inefficient cutting parameters, metal removal rate, power consumption, torque and tool deflection. Force charts also expose cutting condition improvement opportunities. With one click on the Force chart, the user is taken to the exact location in the program and to the graphical review window for further analysis. The end result is full utilization of the cutting tool and the machine tool.”
Okuma’s Lee Johnston agreed. “At the event we were cutting titanium and saw significant improvement, but I think Force is just as suitable for machining easier materials like aluminum, and for other general purpose work. I look forward to using it on future projects.”
  • ARTICLES
    How Midaco Pallet Changers Boost CNC Productivity and OEE
    Kip Hanson November 14, 2025
    Several decades ago, I purchased an SMW pallet changer for one of our shop’s Mori Seiki MV Junior Vertical Machining Centers. This glorious day for overall equipment effectiveness (OEE) occurred many years before SMW’s various acquisitions and its board decided to depart the pallet changer business entirely, seemingly leaving just one provider: Elk Grove Village, Ill.-based Midaco. We had an opportunity to ask the company’s Vice President of Sales Mike Munao a few questions, starting with one we were unsure he would answer.
    Materialise Unveils Software and Automation Technologies
    PRESS RELEASE: Materialise NV November 14, 2025
    Materialise NV, a global leader in additive manufacturing (AM) software and services, announced the next phase of its open and secure software-ecosystem strategy today, introducing three tailored CO-AM solutions and new enabling technologies to address the industry’s growing need for workflow automation and interoperability.
  • SMART SHOP ESSENTIALS
    Mitotec Precision’s Bold CNC Investments Drive Growth and Innovation
    Staff Writer November 13, 2025
    Whether it’s an unfamiliar brand or an entirely new kind of machine tool, buying equipment you’ve never operated before is a scary proposition for any manufacturer—especially for the small- to medium-sized businesses that make up so much of America’s manufacturing base.
