Lasers and Robots: Marriage of Convenience
Bill Koenig
By Bill Koenig Senior Editor, SME Media
As both robots and lasers improve their capabilities, they prove to be even better partners in more applications
Lasers and robots have long worked together. Robots (and other automation) commonly serve to guide lasers in welding, marking and other processes. Robotic laser systems are familiar sights in the automotive industry, where over time both sides of the partnership have seen their accuracy and productivity improve, thanks in no small part to ever more sophisticated software. As a result, laser robotic systems are seeing wider use in other industries, including aerospace.
“The biggest driver in laser applications recently has been the cost performance,” said Mike Sharpe, staff engineer in the materials joining group of FANUC America Corp. (Rochester Hills, MI).
“Fiber lasers…all those types of one-micron wavelength lasers are solid state in nature and that’s really driven the cost down and improved the efficiency of the lasers,” Sharpe said. “Multikilowatt lasers now become more mainstay because they’re affordable—affordable to operate versus CO2 and other methods of lasing and they’re easy to manage because of the fiber delivery, which lends itself to robotics.”
“The automotive segment pushes to use robotics due to their familiarity with the technology and the favorable price point and greater flexibility compared to hard automation or custom solutions,” said Doug Hixon, a North Carolina-based robotics application engineer for ABB Robotics’ US unit (Auburn Hills, MI). “Robots are purchased in such large volumes in automotive that the price is attractive if the robot is capable of performing the task.”
Lasers and robots are natural partners, according to manufacturers.
“Laser welding and cutting can’t be done by hand,” Andy Hromadka, project integration manager for Trumpf Inc. (Farmington, CT), a maker of fabricating equipment and industrial lasers, said in an email. “Automation is required in some form and we collaborate with robot manufacturers and robotic systems integrators to implement laser processing systems.”
Often, the end customer selects which laser system it wants to pair with which robot. “We strive to make a robot that will accept and work with any tool, provided it fits within the payload of the robot,” said Daniel Moore, technical support manager for Universal Robots USA Inc. (Ann Arbor).
A laser cutting operation is performed using an ABB robot.
“While we do not directly work with any laser company, the path repeatability and point repeatability of the robot is available to any application, laser or not,” he said. “We also provide a very open architecture, allowing for companies to design their own plugins and software modules to speed up interfacing between the robot and the laser system and allow customization directly on the robot pendant.”
Prima Power Laserdyne (Champlin, MN), a maker of laser and sheetmetal machinery, is involved with aerospace, particularly aircraft engines. “What we do, what the machines we build do, is produce holes,” said Terry VanderWert, the company president. “The precision of that hole determines the consistency of the air flow.” With more precisely made holes, he said, aircraft engines can have improved air flow and lower fuel consumption.
“Increasing the precision of the laser-processed feature has enabled new designs and new features,” VanderWert said. “We’re competing against other technologies.”
What follows is a look at how different players in the industry approach the market.
Auto Industry Demand
A robotic laser application is performed at a General Motors Co. plant
“Automotive technology has driven laser applications,” said FANUC’s Sharpe. “Automotive tends to have deeper pockets than general industrial and quicker programs than, let’s say, aerospace.
“Back in the late ’90s, it was hydroforming,” Sharpe said. “Hydroform is where you blow up a tube to get a net shape and you can then make supposedly cheaper, lighter, stronger or more tailored car parts. But the problem is you can’t cut them with a stamping die, you need to trim them mechanically or with a laser.”
Hydroforming was used on large pickup models. “Those big programs drove volume,” he said. “By driving the volume, that allowed laser manufacturers to invest at lower cost.”
More recently, the industry had used high-strength steels. Such steels are stronger than traditional steels, so less of the material is needed. That’s one strategy automakers are using to make vehicles lighter so they can meet federal fuel efficiency standards.
“Those you can’t really trim in a die,” Sharpe said. “If you trim them in a die, your die life…you’ll get a few hundred cycles.” As a result, he said, that has encouraged using robotic laser devices for cutting.
Other lightweighting strategies include using aluminum, which necessitates new ways of joining aluminum to steel while avoiding corrosion. That also has led to using robotic laser devices more, he said.
“In the last few years, we’re seeing more of the US nameplates doing what the Europeans have been doing probably for a decade….taking aluminum structures and gluing it to a galvanized sheetmetal and riveting it to something else,” he said. “Those things are really coming around.”
FANUC is involved with production of General Motors Co.’s Cadillac CT6, which uses a mix of aluminum and high-strength steels. The luxury four-door is the lead application for a GM-developed steel-to-aluminum spot welding process.
With lightweighting and using new materials, “It’s very effective for people to apply robotics in those applications,” Sharpe said. “Lasers have gone down [in cost]. Material science is being proved and that allows them to apply the technologies together and make better vehicles for us.”
A FANUC robot equipped with a laser for welding applications.
Advancements in laser robotics have spurred increased use in aerospace, he said.
“A lot of the stuff we’re doing is specific to hard facing the struts and the screws of a turbine,” Sharpe said. For repair work, a laser process “with powdered metal or a wire-fed system” can be used “to build those back up,” he said. Also, with composite materials, lasers can be used to clean surfaces before adhesives are applied, he said.
Additive manufacturing also opens up opportunities for increased use of laser robotic systems. While 3D printing produces parts directly from a digital design, many of these parts still have rough surfaces that require additional work. “Laser robotics can be used for processing: machining, smoothing, grinding or whatever,” Sharpe said.
“We are experts at motion and motion planning and control,” he said. “We also have an expertise in laser process and controls. Our scope is to bring that together to market but we also work together with others as customers require.”
One of FANUC’s priorities is improving the precision of its robots. With increased precision, Sharpe said, “the more applications you can do.”
‘More Stable’
One company that has worked with FANUC is Prima Power Laserdyne. The two collaborated on a system for an aerospace customer that VanderWert declined to identify, where a FANUC robot loaded and unloaded parts.
“Normally one doesn’t think of low-volume production as a case for robotic load and unload,” said Prima’s VanderWert. “The customer said he wanted it.” That’s because the customer found a “machine went underutilized. Invariably the operator would be on break when the part was finished.” The customer “wanted to automate the load and unload of parts.”
A UR5 robot from Universal Robots with a Rofin 20-W fiber laser engraves anodized aluminum business cards at Canadian manufacturer The Ringlord (www.theringlord.com).
Prima Industrie, Prima Power’s parent, originally started by making articulated-arm robots in the late 1970s for inspection applications. Prima Power Laserdyne entered into making laser systems using Cartesian robots with three linear axes and two rotary axes.
“Laser sources today are more stable,” VanderWert said. “The machines are more stable.”
Robotic laser systems also will be affected by Internet of Things technology that enables machines to communicate with each other and allows operators to monitor equipment via smartphones and tablets.
“We’re very early in that. In new machines, you can collect a lot of data that most customers don’t know what to do with,” he said in a follow-up email. IoT will probably first help with preventative maintenance “so there’s no real hiccup in product coming off the laser.”
‘Less Complex’
Trumpf’s Hromadka said “the single biggest improvement” is how “lasers are simpler to use, maintenance free and less complex.” Both the laser and robots “are being driven by the same thing in industry for 24/7 uptime. They’re driven by the same industrial motivations.”
Operators “will receive a different type of training because of the sophistication of these systems,” he said.
“We’ll see the needs for technicians that have a higher skill level. Automation cuts back the need for training in manual tasks but the system is more sophisticated and so the job training will need to address that as well,” Hromadka said. “I don’t think there will be a cutback on the amount of training.”
Software Improvements
ABB’s Hixon, on the other hand, said, “Software has been the biggest improvement with respect to laser applications.”
“Robotic offline programming software has improved the quality of programming that was previously relied on by point-to-point programming,” he said. At the same time, he said, “Motion algorithms have improved over the years to fine tune speeds and accelerations while minimizing positional error.”
More improvements are expected in coming years.
“A big advancement on the horizon is the robot learning by doing,” Hixon said. “Integration into self-calibration techniques and self-learning to optimize performance are areas where robots will continue to improve.”
Hixon also said training is important but should be done by a “technology champion” at the customer.
“So rather than a whole staff of trained employees the newer robotic technology is easier to learn through hands-on experience. But a clear technology leader still needs to be part of the equation.”
Vision Systems
Moore of Universal Robots also said laser systems have gotten more affordable.
“Now even small shops could conceivably afford a laser welding system,” Moore said. “The ability to channel a laser down a flexible fiber-optic [tube] rather than a system of mirrors means it is easy to mount a small laser system on nearly any robot. Laser scanners and marking tools, particularly inspection tools, have thus seen an increase in demand which has prompted further innovation.”
Moore said vision systems will improve as processors get better. “This will lead to even better inspection tools and optics,” he said. “Galvo scanners will continue to improve, shrinking in size.”
IoT presents the industry with potential gains and challenges, he said.
“Our own robot has a system of passwords to protect its operations and only allows operator-selected inputs from outside systems,” Moore said. “Far too many IoT systems have few or zero protections from hacking, script injections or remote monitoring from unintended persons.”
    Rootstock Software Acquires Praxis Solutions, Appoints Vice President of Product
    PRESS RELEASE: Rootstock Software November 17, 2025
    Rootstock Software, a recognized leader in cloud ERP for product-based companies, today announced its acquisition of Praxis Solutions, LLC, a Salesforce consulting and implementation firm with a long-standing partnership with Rootstock. Rootstock is backed by Gryphon Investors, a leading middle-market private investment firm.
  • AEROSPACE DEFENSE
    How High-Speed Machining in Aerospace Is Evolving Through Tools, Software and Human Insight
    Meaghan Ziemba, Contributing Editor November 17, 2025
    In aerospace manufacturing, “high speed” is a moving target. For some, it’s a spindle running at 30,000 revolutions per minute. For others, it’s about how efficiently a process turns aluminum stock into a completed rib, spar or bulkhead without deflection or rework.
    Toyota Opens North Carolina Battery Facility
    Staff Writer November 17, 2025
    Toyota Motor Corp. has started production at its new $13.9-billion electric vehicle battery plant in Liberty, N.C.
